소개
This guide is a walkthrough on how to replace the lithium battery on your Kobo Arc 7. This guide requires fairly simple tools that are all found in the ifixit tool kit and is simple and easy to understand.
필요한 것
Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Top pour redémarrer un kobo arc 7 en décharge profonde : débrancher la batterie, connexion chargeur (ça s'allume!), déconnection chargeur, rebrancher la batterie et mettre en charge. Par contre la batterie est introuvable.. on verra une fois chargé si ça tiens encore. merci
