주요 콘텐츠로 건너뛰기
Kobo Arc K107 Battery Replacement
필요한 것
  1. Kobo Arc K107 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Battery Replacement: 3 단계, 이미지 1/1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Battery Replacement: 4 단계, 이미지 1/1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephen Pehl
회원 가입일: 10/28/21
303 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G3
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Top pour redémarrer un kobo arc 7 en décharge profonde : débrancher la batterie, connexion chargeur (ça s'allume!), déconnection chargeur, rebrancher la batterie et mettre en charge. Par contre la batterie est introuvable.. on verra une fois chargé si ça tiens encore. merci
vincepolshki - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 41
전체 시간: 1,350
