주요 콘텐츠로 건너뛰기
Kobo Arc K107 Speaker Replacement
필요한 것
  1. Kobo Arc K107 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Speaker Replacement: 3 단계, 이미지 1/1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Speaker Replacement: 4 단계, 이미지 1/1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Speaker Replacement, Speaker: 5 단계, 이미지 1/2 Kobo Arc K107 Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Kobo Arc K107 Speaker Replacement: 6 단계, 이미지 1/1
    • Disconnect the speakers from the tablet.
결론
Luke Maalouf
회원 가입일: 10/28/21
85 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 14
전체 시간: 90
