주요 콘텐츠로 건너뛰기
Kobo Aura Rear Cover Replacement
필요한 것
  1. Kobo Aura Rear Cover Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
    • If you haven't done so already, power off your eReader by sliding and holding the power switch for 3 seconds until the display refreshes to indicate that it has powered off.
    • When inserting your opening tools/picks at this step, do not insert it in the gap on the front, as this is where the front panel attaches.
    • Insert it on the side.
  2. Kobo Aura Rear Cover Replacement: 2 단계, 이미지 3개 중 1개 Kobo Aura Rear Cover Replacement: 2 단계, 이미지 3개 중 2개 Kobo Aura Rear Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Insert your opening tool in the seam, starting at the top.
    • You could start at the side or the bottom, but you may find that the shell may be harder to pry apart.
    • If you're only using an opening tool:
    • Use the tool to undo clips located in these areas.
    • If you're using both an opening tool and pick:
    • Use the tool to open a gap small enough that you can slide a pick into
    • and slide it around the side to undo clips located in these areas.
    • You may have to switch between the opening tools and picks.
  3. Kobo Aura Rear Cover Replacement: 3 단계, 이미지 3개 중 1개 Kobo Aura Rear Cover Replacement: 3 단계, 이미지 3개 중 2개 Kobo Aura Rear Cover Replacement: 3 단계, 이미지 3개 중 3개
    • The rear cover can now come off.
    • The plastic cover for the power switch will usually fall inside or fall out. Don't lose this!
    • However, the plastic cover for the front light toggle is usually attached to the rear cover, unless it has broken off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kevin Bhasi
회원 가입일: 12/26/14
1,262 평판
안내서 9개를 작성함
댓글 3개
Can I fix a scrambled screen? Kobo Aura N514
W B - 답글
Can I fix the screen of my kobo aura H2O?
Zoe Likkel - 답글
Merhaba, Kobo Aura N514 cihazımın ekranı beyazlaştı. Sanırım ekran değişimi yapılacak bu konuda yardımcı olabilir misiniz lütfen..
Kadir Öztürk - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 80
전체 시간: 1,328
