주요 콘텐츠로 건너뛰기
Kobo Glo HD Display Replacement
필요한 것
  1. Kobo Glo HD Display Replacement, Rear Cover: 1 단계, 이미지 3개 중 1개 Kobo Glo HD Display Replacement, Rear Cover: 1 단계, 이미지 3개 중 2개 Kobo Glo HD Display Replacement, Rear Cover: 1 단계, 이미지 3개 중 3개
    • If you haven't done so already, power off your eReader by holding down the power button for 3 seconds until the display refreshes to indicate that it has powered off.
    • Opening picks are required for this step as opening tools can be too wide to get into the gap between the rear cover and the side/front.
    • Start by inserting the pick into the area around the power button or Micro USB port.
    • Don't insert it too far, as that could result in damage to the power button, status indicator, and/or Micro USB port.
    • Then, slide the pick around to undo these clips.
  2. Kobo Glo HD Display Replacement: 2 단계, 이미지 3개 중 1개 Kobo Glo HD Display Replacement: 2 단계, 이미지 3개 중 2개 Kobo Glo HD Display Replacement: 2 단계, 이미지 3개 중 3개
    • The rear cover should then pop off.
  3. Kobo Glo HD Display Replacement, Mainboard - Disconnect the battery: 3 단계, 이미지 3개 중 1개 Kobo Glo HD Display Replacement, Mainboard - Disconnect the battery: 3 단계, 이미지 3개 중 2개 Kobo Glo HD Display Replacement, Mainboard - Disconnect the battery: 3 단계, 이미지 3개 중 3개
    • Using the pointed end of your spudger, while holding your eReader using your other hand or a weight, disconnect the battery.
  4. Kobo Glo HD Display Replacement, Remove the internal memory card: 4 단계, 이미지 2개 중 1개 Kobo Glo HD Display Replacement, Remove the internal memory card: 4 단계, 이미지 2개 중 2개
    • If your eReader has a memory card instead of a storage chip, remove the memory card.
    • Don't lose, misplace, or damage this memory card, as it not only contains any books and any other data you downloaded or copied over, but it also contains the firmware, as well as the serial number and important files required for your eReader to be able to start up.
    • Image needed in position 1: innards after disconnecting the battery
  5. Kobo Glo HD Display Replacement, Disconnect the display: 5 단계, 이미지 2개 중 1개 Kobo Glo HD Display Replacement, Disconnect the display: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the flat end of your spudger and a pair of flat-bladed tweezers, disconnect the display.
    • Image needed: innards after disconnecting the battery and removing the start-up memory card
  6. Kobo Glo HD Display Replacement, Disconnect the frontlight: 6 단계, 이미지 2개 중 1개 Kobo Glo HD Display Replacement, Disconnect the frontlight: 6 단계, 이미지 2개 중 2개
    • Using the pointed end of your spudger, disconnect the frontlight.
    • Image needed: innards after disconnecting the battery, removing the start-up memory card, and disconnecting the display
  7. Kobo Glo HD Display Replacement, Remove the mainboard: 7 단계, 이미지 2개 중 1개 Kobo Glo HD Display Replacement, Remove the mainboard: 7 단계, 이미지 2개 중 2개
    • Using your screwdriver with a PH00 tip, remove these screws and set them aside.
  8. Kobo Glo HD Display Replacement: 8 단계, 이미지 1개 중 1개
    • Use the flat end of your spudger to lift the top of the mainboard, and your fingers to slowly pull out the bottom.
    • Image needed: me pulling out the mainboard
  9. Kobo Glo HD Display Replacement: 9 단계, 이미지 3개 중 1개 Kobo Glo HD Display Replacement: 9 단계, 이미지 3개 중 2개 Kobo Glo HD Display Replacement: 9 단계, 이미지 3개 중 3개
    • The mainboard has been removed.
  10. Kobo Glo HD Display Replacement, Front Bezel: 10 단계, 이미지 1개 중 1개
    • Remove these screws, and keep them aside.
    • Image needed: me unscrewing the bezel screws
  11. Kobo Glo HD Display Replacement: 11 단계, 이미지 2개 중 1개 Kobo Glo HD Display Replacement: 11 단계, 이미지 2개 중 2개
    • Now comes the start of the hard part.
    • Press down on the display to slowly free the display assembly from the bezel.
    • Don't press down too hard, as doing so may result in damage to the bezel.
    • This may take 5-15 minutes.
  12. Kobo Glo HD Display Replacement: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Once you have freed the display assembly from the bezel, use the tweezers to reposition any bits of double-sided tape that may have come loose.
    • Image needed depicting this
    • Place the bezel off to the size, face up.
    • The front bezel has been removed.
  13. Kobo Glo HD Display Replacement, Display assembly - Removing the infrared light guide: 13 단계, 이미지 3개 중 1개 Kobo Glo HD Display Replacement, Display assembly - Removing the infrared light guide: 13 단계, 이미지 3개 중 2개 Kobo Glo HD Display Replacement, Display assembly - Removing the infrared light guide: 13 단계, 이미지 3개 중 3개
    • Press down on the display while using your fingernail in between the infrared light guide and mid-frame in order to separate the former from the latter and EPD panel that's still attached to it.
    • Don't press down too hard, as doing so may result in damage to the infrared light guide, which may result in erratic touch input and/or unresponsive areas on the display once reassembled.
    • The infrared light guide has been removed.
  14. Kobo Glo HD Display Replacement: 14 단계, 이미지 3개 중 1개 Kobo Glo HD Display Replacement: 14 단계, 이미지 3개 중 2개 Kobo Glo HD Display Replacement: 14 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Use your thumb and finger on the rear-facing side of the mid-frame to pry apart part of the mid-frame, enough for you to slip your plastic card into.
    • Don't press on the battery, as doing so can puncture it, resulting in damage and serious injury.
    • Slip the card in between the EPD panel and mid-frame, and pull it around the perimeter and push it in and out, in order to break adhesive holding the former in place.
    • You may need to use your thumb and finger to bend the mid-frame and break some of the adhesive.
  15. Kobo Glo HD Display Replacement: 15 단계, 이미지 1개 중 1개
    • The EPD panel has been removed from the mid-frame.
    • (Placeholder for details on preparing the EPD panel, lightly cleaning the back of it, adding double-sided tape)
    • Without the tape, the back of the EPD panel may get scratched by the midframe, and the infrared light guide won't sit flush with the bezel.
    • Do not press down on the display panel yet, in the event that the display may have to be removed again.
    • (Placeholder for details on aligning the display panel to the mid-frame)
  16. Kobo Glo HD Display Replacement, Testing the replacement EPD panel (optional): 18 단계, 이미지 1개 중 1개
    • Optionally, you can insert the memory card back onto the mainboard, and connect your eReader to an external power source in order to test the replacement EPD panel for any artefacts and/or dead pixels.
    • This process of testing EPD panels without connecting the battery, frontlight, touch, and/or pen input (depending on model) is basically the same process used by suppliers of new-old-stock EPD panels in China, when they sell them on online stores like AliExpress and/or eBay, which you would've most likely purchased your display panel from.
    • However, they would sometimes test displays on another device that uses the same display or used a display with similar specifications, in order to not have too many test devices around, for example, a Kobo Aura display tested using a Kindle Paperwhite 2, or a Likebook Mars display tested using a Dangdang Reader R7.
    • At this stage, you should not have the infrared light guide attached to the panel but not to the mid-frame, which is what the photo shows as I made mistakes while writing this guide, so that you don't have to.
    • You should instead have the display panel loosely attached to the mid-frame, without the infrared light guide and front bezel attached at this stage.
    • Connect a USB cable from a USB power adaptor or external battery to your eReader, and it should automatically power on.
    • Without the infrared light guide, you will not be able to navigate menus on your eReader and open a book or Pocket article, but you will still be able to use the power button to take it in and out of sleep mode, and power off.
    • Don't mind the weird selection of books in the middle row, but I had not removed the previous owner's sideloaded e-books before carrying out this repair.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kevin Bhasi
회원 가입일: 12/26/14
1,262 평판
안내서 9개를 작성함
댓글 3개
Thank you for the detailed guide! I don't know why this didn't show up on glo hd's page. Google found it for me.
Much much appreciated your work
One more point, is it reaaaally important to tape the display to the mid frame?
Soma Schicksal - 답글
I'll try to check the category settings. I remembered that the Glo HD page was messed up and I saw Kobo Aura tutorials listed under the Kobo Glo page.
Thanks! I'm actually busy working on other projects at the moment, and don't have the time to continue working on iFixit and Wikipedia articles, but I hope to find the time to continue doing so.
Yes, I believe it is.
I actually didn't tape the display to the mid-frame on mine, as I don't actually have the tape I need, but as a result, the infrared light guide had sunken in after reassembly, and doesn't sit flush with the bezel like it would do with the tape in place. Other than that, it works.
Mine does have a dead pixel near the bottom right corner of the screen, but that was just from me incorrectly installing the display the first time around while writing the guide.
Kevin Bhasi -
Hi!
Thanks for this very clear guide! I was wondering if i wanted to test if the infrared light is working what is the minimal units and cables that have to be connected?
Thank you very much!
Alessandro - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 27
지난 30일: 109
전체 시간: 3,452
