소개
This guide will help you fix a problem where the battery connection comes loose causing the Kobe Vox to not boot
You can also use this guide to replace the battery entirely.
필요한 것
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse order. All you have to do is snap in the back cover.
결론
다른 6명이 해당 안내서를 완성하였습니다.
