주요 콘텐츠로 건너뛰기
Kobo Vox Battery Replacement
필요한 것
  1. Kobo Vox Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Your Kobo Vox
  2. Kobo Vox Battery Replacement: 2 단계, 이미지 1/1
    • The back of your Kobo Vox
  3. Kobo Vox Battery Replacement: 3 단계, 이미지 1/1
    • Slide your plastic opening tool along the edge of the back cover to pop it open.
  4. Kobo Vox Battery Replacement: 4 단계, 이미지 1/1
    • The back cover should start to pop open like this.
  5. Kobo Vox Battery Replacement: 5 단계, 이미지 1/1
    • During Reassembly this is where the plastic snaps are located on the back cover. They will have to be lined up in order for it to snap back into place correctly.
  6. Kobo Vox Battery Replacement: 6 단계, 이미지 1/1
    • This is what the inside of your Kobo Vox should look like
  7. Kobo Vox Battery Replacement: 7 단계, 이미지 1/1
    • If the battery connector looks like this, it may not be making perfect contact, and your tablet may not turn on properly.
  8. Kobo Vox Battery Replacement: 8 단계, 이미지 1/1
    • Push the connector as far into its socket as you can.
    • You can put a piece of tape over this connector if you are afraid it will disconnect again.
결론
To reassemble your device, follow these instructions in reverse order. All you have to do is snap in the back cover.
다른 6명이 해당 안내서를 완성하였습니다.
Nick B
회원 가입일: 10/13/14
292 평판
안내서 1개 작성함
댓글 한 개
hoe and where do I get replacement battery
terryyvette - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 15
전체 시간: 3,394
