주요 콘텐츠로 건너뛰기
Kodak EasyShare C195 Batteries Replacement
필요한 것
  1. Kodak EasyShare C195 Batteries Replacement, Batteries: 1 단계, 이미지 1/3 Kodak EasyShare C195 Batteries Replacement, Batteries: 1 단계, 이미지 2/3 Kodak EasyShare C195 Batteries Replacement, Batteries: 1 단계, 이미지 3/3
    • First, open the cover to the batteries. This is located on the bottom left of the camera.
    • Push the door down and to the left to open. This opens into the batteries and the memory card.
  2. Kodak EasyShare C195 Batteries Replacement: 2 단계, 이미지 1/3 Kodak EasyShare C195 Batteries Replacement: 2 단계, 이미지 2/3 Kodak EasyShare C195 Batteries Replacement: 2 단계, 이미지 3/3
    • To insert the batteries, place them in the slots provided.
    • Make sure the positive and negative signs match with the positive and negative sides of the batteries.
  3. Kodak EasyShare C195 Batteries Replacement: 3 단계, 이미지 1/3 Kodak EasyShare C195 Batteries Replacement: 3 단계, 이미지 2/3 Kodak EasyShare C195 Batteries Replacement: 3 단계, 이미지 3/3
    • When finished, you should have one battery positive side up and the other one negative side up.
결론
To close the door, push the door down and slide to the right
Alyssa
회원 가입일: 04/12/12
81 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-22, Amido Spring 2012 Cal Poly, Team 6-22, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G22
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 67
전체 시간: 3,098
