이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
To start, remove the Philips #00 4.5 mm screws on both sides of the camera.
On the bottom, there are three Philips #00 4.5 mm screws. Two are for the front panel and one is for the back panel. To remove the back panel, take out the screws indicated in the final picture of the sequence.
Once all the screws are out, remove the back panel.
To do this, start by removing the bottom of the panel.
Once the bottom part is unhooked, unhook the top, and the whole panel should come off.
Be sure to gently pry the cover off.
In the top right hand corner of the inside of the camera, there is a Philips #00 4 mm screw that needs to be removed.
The next step is to remove the white ribbon on the upper right hand corner next to the LCD screen.
This can be done with or without tweezers.
To remove the screen completely, push down on the rectangular tab indicated in the picture.
다른 4명이 해당 안내서를 완성하였습니다.
