소개
This guide will show you how to remove the internal lens of your camera.
필요한 것
To start, remove the Philips #00 4.5 mm screws on both sides of the camera.
On the bottom, there are three Philips #00 4.5 mm screws. Two are for the front panel and one is for the back panel. To remove the back panel, take out the screws indicated in the final picture of the sequence.
다른 2명이 해당 안내서를 완성하였습니다.
