주요 콘텐츠로 건너뛰기
Kodak EasyShare C713 Battery Door Replacement
필요한 것
  1. Kodak EasyShare C713 Battery Door Replacement, Batteries: 1 단계, 이미지 1/1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Battery Door Replacement: 2 단계, 이미지 1/1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Battery Door Replacement, Outer Case: 3 단계, 이미지 1/3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: 3 단계, 이미지 2/3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: 3 단계, 이미지 3/3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Battery Door Replacement: 4 단계, 이미지 1/3 Kodak EasyShare C713 Battery Door Replacement: 4 단계, 이미지 2/3 Kodak EasyShare C713 Battery Door Replacement: 4 단계, 이미지 3/3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Battery Door Replacement, Battery Door: 5 단계, 이미지 1/2 Kodak EasyShare C713 Battery Door Replacement, Battery Door: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Trevor DeVore
회원 가입일: 04/15/10
17 평판
안내서 1개 작성함
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 회원
CPSU-REGAN-S10S26G19
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Where do I buy a new battery door. Cheers, Peter
Peter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 5,219
