소개
Replacing the camera buttons.
필요한 것
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Remove the necessary broken buttons.
They come out easily so just use your fingers.
다른 한 분이 해당 안내서를 완성하였습니다.
