주요 콘텐츠로 건너뛰기
Kodak EasyShare C713 LCD Replacement
필요한 것
  1. Kodak EasyShare C713 LCD Replacement, Batteries: 1 단계, 이미지 1개 중 1개
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 LCD Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: 3 단계, 이미지 3개 중 1개 Kodak EasyShare C713 LCD Replacement, Outer Case: 3 단계, 이미지 3개 중 2개 Kodak EasyShare C713 LCD Replacement, Outer Case: 3 단계, 이미지 3개 중 3개
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: 4 단계, 이미지 3개 중 1개 Kodak EasyShare C713 LCD Replacement: 4 단계, 이미지 3개 중 2개 Kodak EasyShare C713 LCD Replacement: 4 단계, 이미지 3개 중 3개
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: 5 단계, 이미지 1개 중 1개
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: 7 단계, 이미지 2개 중 1개 Kodak EasyShare C713 LCD Replacement: 7 단계, 이미지 2개 중 2개
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: 8 단계, 이미지 1개 중 1개
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: 9 단계, 이미지 1개 중 1개
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the LCD ribbon cable from inside the black tab.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Taggart Ashby
회원 가입일: 04/15/10
354 평판
안내서 4개를 작성함
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 회원
CPSU-REGAN-S10S26G19
4 회원들
안내서 14개를 작성함
2가이드 댓글
Thank you... i fixed my old camera lcd.
anthoxman - 답글
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 5,732
