이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Put your thumb in the upper right corner of the LCD screen.
Pull the LCD screen out of its outer case with your thumb.
Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
After desoldering the LCD casing, just use your fingers to carefully remove it.
Flip up the black tab on the bottom of the LCD screen with a fingertip.
Using a fingertip, flip the black tab near the top of the camera.
Remove the ribbon connector from inside the black tab.
Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
Desolder the upper points.
There is a series of solder points in a rectangular area in the upper middle of the camera.
There is a large solder point in the upper right.
Turn the camera over.
Pry the capacitor out of its holder on the bottom of the camera with your fingers.
Remove the lens assembly with your fingers.
Do not touch the marked areas. This will cause the camera to take blurry pictures.
다른 한 분이 해당 안내서를 완성하였습니다.
