메인 콘텐츠로 스킵하기
소개
How to remove the buttons.
부품
지정된 부품이 없습니다.
  1. Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open, so be careful to lift it up gently.
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open, so be careful to lift it up gently.
  2. Use a Phillips #00 screwdriver to remove the seven 4.5mm screws. There are 2 on the left There are 2 on the right
    • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • There are 2 on the left
    • There are 2 on the right
    • There are 3 on the bottom
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off.
    • Firmly grasp and pull back casing off.
  5. Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons.
    • Use #00 screwdriver to pry off buttons.
결론
Alan Galarza
회원 가입일: 2010년 10월 03일
69 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G51
4 회원들
안내서 7개 작성하였습니다
Thank you this was very helpful!
carolnelson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,186
