주요 콘텐츠로 건너뛰기
Kodak EasyShare C913 Buttons Replacement
필요한 것
  1. Kodak EasyShare C913 Buttons Replacement, Batteries: 1 단계, 이미지 1/3 Kodak EasyShare C913 Buttons Replacement, Batteries: 1 단계, 이미지 2/3 Kodak EasyShare C913 Buttons Replacement, Batteries: 1 단계, 이미지 3/3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 Buttons Replacement, Back Case: 2 단계, 이미지 1/3 Kodak EasyShare C913 Buttons Replacement, Back Case: 2 단계, 이미지 2/3 Kodak EasyShare C913 Buttons Replacement, Back Case: 2 단계, 이미지 3/3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 Buttons Replacement: 3 단계, 이미지 1/3 Kodak EasyShare C913 Buttons Replacement: 3 단계, 이미지 2/3 Kodak EasyShare C913 Buttons Replacement: 3 단계, 이미지 3/3
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 Buttons Replacement, Buttons: 4 단계, 이미지 1/3 Kodak EasyShare C913 Buttons Replacement, Buttons: 4 단계, 이미지 2/3 Kodak EasyShare C913 Buttons Replacement, Buttons: 4 단계, 이미지 3/3
    • Use #00 screwdriver to pry off buttons.
결론
Alan Galarza
회원 가입일: 10/03/10
72 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G51
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Thank you this was very helpful!
carolnelson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,334
