주요 콘텐츠로 건너뛰기
Kodak EasyShare C913 LCD Screen Replacement
필요한 것
  1. Kodak EasyShare C913 LCD Screen Replacement, Batteries: 1 단계, 이미지 3개 중 1개 Kodak EasyShare C913 LCD Screen Replacement, Batteries: 1 단계, 이미지 3개 중 2개 Kodak EasyShare C913 LCD Screen Replacement, Batteries: 1 단계, 이미지 3개 중 3개
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 LCD Screen Replacement, Back Case: 2 단계, 이미지 3개 중 1개 Kodak EasyShare C913 LCD Screen Replacement, Back Case: 2 단계, 이미지 3개 중 2개 Kodak EasyShare C913 LCD Screen Replacement, Back Case: 2 단계, 이미지 3개 중 3개
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 screws on the left
    • 2 screws on the right
    • 3 screws on the bottom
  3. Kodak EasyShare C913 LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 Kodak EasyShare C913 LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 Kodak EasyShare C913 LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Firmly grasp the back of the camera and pull the casing away.
  4. Kodak EasyShare C913 LCD Screen Replacement, Front Case: 4 단계, 이미지 3개 중 1개 Kodak EasyShare C913 LCD Screen Replacement, Front Case: 4 단계, 이미지 3개 중 2개 Kodak EasyShare C913 LCD Screen Replacement, Front Case: 4 단계, 이미지 3개 중 3개
    • Keep the battery door open
    • Firmly grasp the front casing and pull it away from the camera.
  5. Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 3개 중 1개 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 3개 중 2개 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 3개 중 3개
    • Look at the LCD casing and find the two smaller solder joints. One on either side of the camera secures the circuit board's casing. These are usually shiny and metallic points where the casing connects to the board.
    • Apply the tip of the heated smolder to the first joint to remove it. Contiune with the other side.
  6. Kodak EasyShare C913 LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Kodak EasyShare C913 LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Kodak EasyShare C913 LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Gently grasp the lower right side of LCD screen.
    • Lift the screen out of its casing.
    • Remove the 3 mm screw from the LCD casing using a #00 screwdriver.
  7. Kodak EasyShare C913 LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Kodak EasyShare C913 LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Kodak EasyShare C913 LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Gently grab the sides of the LCD casing and remove it from the camera.
  8. Kodak EasyShare C913 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Kodak EasyShare C913 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the black tab gently with your finger.
    • Gently remove ribbon from underneath black tab.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Alan Galarza
회원 가입일: 10/03/10
84 평판
안내서 3개를 작성함
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G51
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 13
전체 시간: 4,703
