주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Kodak EasyShare CD82 LCD Display Screen Replacement
필요한 것
  1. Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Remove the batteries and the memory card from the device.
    • Remove the 2 screws located at the bottom of the device.
  2. Kodak EasyShare CD82 LCD Display Screen Replacement: 2 단계, 이미지 1/3 Kodak EasyShare CD82 LCD Display Screen Replacement: 2 단계, 이미지 2/3 Kodak EasyShare CD82 LCD Display Screen Replacement: 2 단계, 이미지 3/3
    • Remove the 2 screws on the side, to the left of the camera lens.
    • Remove the 2 screws on the side, to the right of the camera lens.
    • Pry the casing from the device starting at the battery compartment and following the seem around the camera.
  3. Kodak EasyShare CD82 LCD Display Screen Replacement: 3 단계, 이미지 1/3 Kodak EasyShare CD82 LCD Display Screen Replacement: 3 단계, 이미지 2/3 Kodak EasyShare CD82 LCD Display Screen Replacement: 3 단계, 이미지 3/3
    • Remove the front panel from the device first, then remove the back panel.
    • Do not remove the LCD screen from the device once it becomes visible.
  4. Kodak EasyShare CD82 LCD Display Screen Replacement: 4 단계, 이미지 1/3 Kodak EasyShare CD82 LCD Display Screen Replacement: 4 단계, 이미지 2/3 Kodak EasyShare CD82 LCD Display Screen Replacement: 4 단계, 이미지 3/3
    • Flip the LCD screen away from the top of the device to reveal the ribbon cable.
    • This is water damage the has afflicted the camera.
    • Remove the 3 screws from the LCD screen holder.
    • Pry the screen holder from the circuit board connector.
  5. Kodak EasyShare CD82 LCD Display Screen Replacement: 5 단계, 이미지 1/2 Kodak EasyShare CD82 LCD Display Screen Replacement: 5 단계, 이미지 2/2
    • Disconnect the logic board from the right side of the frame.
    • Remove the small ribbon cable that is connecting the button panel to the logic board, using a small pair of tweezers or hemostat.
    • Remove the screw on the top right side of the device.
  6. Kodak EasyShare CD82 LCD Display Screen Replacement: 6 단계, 이미지 1/2 Kodak EasyShare CD82 LCD Display Screen Replacement: 6 단계, 이미지 2/2
    • Open the connector and move the black clip into the upward position, freeing the cable. Remove the LCD screen and the holder.
    • While the camera is disassembled, use isopropyl alcohol to remove rust and clean the device.
    • Follow these steps in reverse order to reassemble. The device should be fully functional upon completion.
결론
다른 2명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
781,172 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
32 회원들
안내서 530개 작성하였습니다
댓글 한 개
Is there any repair for Kodak CD80 easy share camera…..as my camera is not working
Januchowdary - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 1,475
