주요 콘텐츠로 건너뛰기
Kodak EasyShare LS743 Battery Door Replacement
필요한 것
  1. Kodak EasyShare LS743 Battery Door Replacement, Battery: 1 단계, 이미지 1/1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Battery Door Replacement: 2 단계, 이미지 1/1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 3 단계, 이미지 1/3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 3 단계, 이미지 2/3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 3 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Battery Door Replacement: 4 단계, 이미지 1/3 Kodak EasyShare LS743 Battery Door Replacement: 4 단계, 이미지 2/3 Kodak EasyShare LS743 Battery Door Replacement: 4 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Battery Door Replacement: 5 단계, 이미지 1/2 Kodak EasyShare LS743 Battery Door Replacement: 5 단계, 이미지 2/2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Battery Door Replacement, Battery Door: 6 단계, 이미지 1/2 Kodak EasyShare LS743 Battery Door Replacement, Battery Door: 6 단계, 이미지 2/2
    • Remove loose battery door.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Odessa
회원 가입일: 06/24/10
55 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-8, Johann Summer 2010 Cal Poly, Team 2-8, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G8
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 1,731
