소개
This will teach you how to remove the capacitor in your Kodak EasyShare LS743.
부품
지정된 부품이 없습니다.
Remove 7 screws.
1 (6.25 mm) screw located on the top right corner, next to the view screen.
4 (4.45mm) screws on the bottom of the camera.
2 (2.95mm) screws on the left side of the camera.
Connect the two capacitor wires briefly with a pair of metal tweezers to discharge it. You may see a small spark.
Remove 8 screws.
2 screws in the front (2X 4.31mm).
2 screws on the bottom (2X3.30MM).
4 screws in the back (3x 3.33mm, and 1x 4.34mm).
다른 한 분이 해당 안내서를 완성하였습니다.
