주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Kodak EasyShare LS743 Microphone Replacement
필요한 것
  1. Kodak EasyShare LS743 Microphone Replacement, Battery: 1 단계, 이미지 1/1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Microphone Replacement: 2 단계, 이미지 1/1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 3 단계, 이미지 1/3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 3 단계, 이미지 2/3 Kodak EasyShare LS743 Microphone Replacement, Kodak EasyShare LS743 Camera Case Disassembly: 3 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Microphone Replacement: 4 단계, 이미지 1/3 Kodak EasyShare LS743 Microphone Replacement: 4 단계, 이미지 2/3 Kodak EasyShare LS743 Microphone Replacement: 4 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Microphone Replacement: 5 단계, 이미지 1/2 Kodak EasyShare LS743 Microphone Replacement: 5 단계, 이미지 2/2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: 6 단계, 이미지 1/2 Kodak EasyShare LS743 Microphone Replacement, Top and menu buttons: 6 단계, 이미지 2/2
    • Remove the top panel screw (1x 4.37mm).
  7. Kodak EasyShare LS743 Microphone Replacement: 7 단계, 이미지 1/2 Kodak EasyShare LS743 Microphone Replacement: 7 단계, 이미지 2/2
    • Remove the top panel.
  8. Kodak EasyShare LS743 Microphone Replacement: 8 단계, 이미지 1/2 Kodak EasyShare LS743 Microphone Replacement: 8 단계, 이미지 2/2
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Kodak EasyShare LS743 Microphone Replacement: 9 단계, 이미지 1/3 Kodak EasyShare LS743 Microphone Replacement: 9 단계, 이미지 2/3 Kodak EasyShare LS743 Microphone Replacement: 9 단계, 이미지 3/3
    • Separate the inner casing from the tripod mount.
  10. Kodak EasyShare LS743 Microphone Replacement: 10 단계, 이미지 1/3 Kodak EasyShare LS743 Microphone Replacement: 10 단계, 이미지 2/3 Kodak EasyShare LS743 Microphone Replacement: 10 단계, 이미지 3/3
    • Gently pull the orange tab out of the circuit board.
  11. Kodak EasyShare LS743 Microphone Replacement: 11 단계, 이미지 1/2 Kodak EasyShare LS743 Microphone Replacement: 11 단계, 이미지 2/2
    • Carefully separate and flip over the LCD panel to expose the central circuit board.
  12. Kodak EasyShare LS743 Microphone Replacement: 12 단계, 이미지 1/1
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Kodak EasyShare LS743 Microphone Replacement: 13 단계, 이미지 1/2 Kodak EasyShare LS743 Microphone Replacement: 13 단계, 이미지 2/2
    • Pull the second orange tab from the circuit board and remove the buttons.
  14. Kodak EasyShare LS743 Microphone Replacement, Removing LCD: 14 단계, 이미지 1/3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: 14 단계, 이미지 2/3 Kodak EasyShare LS743 Microphone Replacement, Removing LCD: 14 단계, 이미지 3/3
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
  15. Kodak EasyShare LS743 Microphone Replacement, Microphone: 15 단계, 이미지 1/1
    • Locate the microphone on top of the camera
  16. Kodak EasyShare LS743 Microphone Replacement: 16 단계, 이미지 1/1
    • With a pry bar, remove microphone away from camera carefully.
  17. Kodak EasyShare LS743 Microphone Replacement: 17 단계, 이미지 1/1
    • Release it from it's pin and desolder
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Odessa
회원 가입일: 06/24/10
55 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-8, Johann Summer 2010 Cal Poly, Team 2-8, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G8
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 2,008
