이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replace unusable or damaged button.
필요한 것
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
다른 한 분이 해당 안내서를 완성하였습니다.
