주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Apple Watch Kits
    Screen and battery repairs just got easier.
    지금 장보기
    Apple Watch Kits
    지금 장보기
  5. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  6. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  7. Open the battery door and identify the retaining pin. Push retaining pin out with small tweezers. Push retaining pin out with small tweezers.
    • Open the battery door and identify the retaining pin.
    • Push retaining pin out with small tweezers.
  8. Once pin is out halfway, close door to ensure no loose parts get lost. Continue to pull out the remaining length of the pin. Continue to pull out the remaining length of the pin.
    • Once pin is out halfway, close door to ensure no loose parts get lost.
    • Continue to pull out the remaining length of the pin.
  9. Gently lift off door cover. Gently lift off door cover.
    • Gently lift off door cover.
결론
Kyanna
회원 가입일: 2014년 03월 13일
313 평판
안내서 3개 작성하였습니다
New Mexico State, Team 1-2, Easley Spring 2014 New Mexico State, Team 1-2, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 57
