주요 콘텐츠로 건너뛰기
Kodak EasyShare M2008 Device Casing Replacement
필요한 것
  1. Kodak EasyShare M2008 Device Casing Replacement, Battery: 1 단계, 이미지 1/2 Kodak EasyShare M2008 Device Casing Replacement, Battery: 1 단계, 이미지 2/2
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Device Casing Replacement: 2 단계, 이미지 1/2 Kodak EasyShare M2008 Device Casing Replacement: 2 단계, 이미지 2/2
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Device Casing Replacement, Device Casing: 3 단계, 이미지 1/3 Kodak EasyShare M2008 Device Casing Replacement, Device Casing: 3 단계, 이미지 2/3 Kodak EasyShare M2008 Device Casing Replacement, Device Casing: 3 단계, 이미지 3/3
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Device Casing Replacement: 4 단계, 이미지 1/3 Kodak EasyShare M2008 Device Casing Replacement: 4 단계, 이미지 2/3 Kodak EasyShare M2008 Device Casing Replacement: 4 단계, 이미지 3/3
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Device Casing Replacement: 5 단계, 이미지 1/3 Kodak EasyShare M2008 Device Casing Replacement: 5 단계, 이미지 2/3 Kodak EasyShare M2008 Device Casing Replacement: 5 단계, 이미지 3/3
    • Remove screws along side.
    • Gently peel off side casing.
결론
Kyanna
회원 가입일: 03/13/14
313 평판
안내서 3개 작성하였습니다
New Mexico State, Team 1-2, Easley Spring 2014 New Mexico State, Team 1-2, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 8
전체 시간: 159
