  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  6. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  7. Gently lift up the LCD screen after removing back casing. Find the point where the orange ribbon cable attaches to mother board.
    • Gently lift up the LCD screen after removing back casing.
    • Find the point where the orange ribbon cable attaches to mother board.
  8. Use plastic opening tool to gently lift up on the ribbon cable fastener. Note: It does not take much pressure to release fastener.
    • Use plastic opening tool to gently lift up on the ribbon cable fastener.
    • Note: It does not take much pressure to release fastener.
  9. Lift LCD Screen off of device.
    • Lift LCD Screen off of device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 2014년 03월 13일
252 평판
안내서 2개 작성하였습니다
New Mexico State, Team 1-2, Easley Spring 2014 New Mexico State, Team 1-2, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 105
