이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place thumb firmly on battery cover.
Slide thumb right, the cover should follow and pop up.
Place thumb on orange tab and pull back towards screen.
The battery should pop up.
Gently lift battery out.
Remove screws from along outer edge of casing.
There are 6 screws in total.
Gently lift up the LCD screen after removing back casing.
Find the point where the orange ribbon cable attaches to mother board.
Use plastic opening tool to gently lift up on the ribbon cable fastener.
Note: It does not take much pressure to release fastener.
다른 한 분이 해당 안내서를 완성하였습니다.
