주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  5. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  6. Remove screws from front silver panel. Remove screws from front silver panel. Remove screws from front silver panel.
    • Remove screws from front silver panel.
  7. Lift up ribbon cable fastener with blue plastic opening tool. Gently pull out lens. Gently pull out lens.
    • Lift up ribbon cable fastener with blue plastic opening tool.
    • Gently pull out lens.
  8. To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
    • To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 2014년 03월 13일
252 평판
안내서 2개 작성하였습니다
New Mexico State, Team 1-2, Easley Spring 2014 New Mexico State, Team 1-2, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 163
