주요 콘텐츠로 건너뛰기
Kodak EasyShare M381 Lens/Optics Replacement
필요한 것
  1. Kodak EasyShare M381 Lens/Optics Replacement, Battery: 1 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Lens/Optics Replacement: 2 단계, 이미지 1개 중 1개
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Lens/Optics Replacement, Screen: 3 단계, 이미지 1개 중 1개
    • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
  4. Kodak EasyShare M381 Lens/Optics Replacement: 4 단계, 이미지 1개 중 1개
    • Remove dial button located on top of camera, by gently pulling up.
  5. Kodak EasyShare M381 Lens/Optics Replacement: 5 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 5 단계, 이미지 2개 중 2개
    • Starting at one side, carefully work the chrome frame off of the camera itself.
    • Be careful not to disturb the shutter or flash buttons on top of the camera.
  6. Kodak EasyShare M381 Lens/Optics Replacement: 6 단계, 이미지 1개 중 1개
    • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
  7. Kodak EasyShare M381 Lens/Optics Replacement: 7 단계, 이미지 3개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 7 단계, 이미지 3개 중 2개 Kodak EasyShare M381 Lens/Optics Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
    • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
    • Slide panel away from camera.
  8. Kodak EasyShare M381 Lens/Optics Replacement: 8 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 8 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
    • Screen should now be detached. Gently lift it away from the base of the camera.
  9. Kodak EasyShare M381 Lens/Optics Replacement, Back Panel Frame: 9 단계, 이미지 3개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement, Back Panel Frame: 9 단계, 이미지 3개 중 2개 Kodak EasyShare M381 Lens/Optics Replacement, Back Panel Frame: 9 단계, 이미지 3개 중 3개
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  10. Kodak EasyShare M381 Lens/Optics Replacement: 10 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 10 단계, 이미지 2개 중 2개
    • Using both hands, carefully pull the frame apart from the camera.
  11. Kodak EasyShare M381 Lens/Optics Replacement, Lens/Optics: 11 단계, 이미지 3개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement, Lens/Optics: 11 단계, 이미지 3개 중 2개 Kodak EasyShare M381 Lens/Optics Replacement, Lens/Optics: 11 단계, 이미지 3개 중 3개
    • Locate and remove the four 3.25 mm screws securing the back panel to the frame of the camera using the Phillips #00 screwdriver.
    • Lift up and remove panel, detaching it from the camera frame.
  12. Kodak EasyShare M381 Lens/Optics Replacement: 12 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the three 3.25 mm screws securing the hexagon-shaped, copper panel to the optical device.
    • Gently peel back the main optic ribbon, ensuring it is securely out of the way.
    • This ribbon is very fragile, and, if torn, the camera will not function properly. Handle with care.
  13. Kodak EasyShare M381 Lens/Optics Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the six 3.25 mm screws securing the optic lens to the camera frame.
  14. Kodak EasyShare M381 Lens/Optics Replacement: 14 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 14 단계, 이미지 2개 중 2개
    • Carefully remove the square lens film, ensuring you do not bend it. This film will be in two pieces: a black cover, and a glass square piece. It is very fragile, so handle with care.
    • This film is very fragile. Handle with care.
  15. Kodak EasyShare M381 Lens/Optics Replacement: 15 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 15 단계, 이미지 2개 중 2개
    • There is a small ribbon attaching the optical lens piece to the motherboard. Using a plastic opening tool, gently lift up on this ribbon's clamp, detaching it from the motherboard.
  16. Kodak EasyShare M381 Lens/Optics Replacement: 16 단계, 이미지 3개 중 1개 Kodak EasyShare M381 Lens/Optics Replacement: 16 단계, 이미지 3개 중 2개 Kodak EasyShare M381 Lens/Optics Replacement: 16 단계, 이미지 3개 중 3개
    • The optic assembly should now be free. Use a pry tool to lift it far enough up that you can grab and remove it.
    • Be sure the detached ribbons are held out of the way to avoid any possible damage to them.
결론
작성자
4다른 기여자 명과 함께
Christina Hamby
회원 가입일: 01/30/15
449 평판
안내서 4개를 작성함
1가이드 댓글
I'm with ya up 'til step 2. The right hand back of my camera has controls (zoom in/out, trash/list/info, right/left/up/down, etc. on it and no visible screws as in your step 3 picture. It appears that another panel has been removed to expose these screws. Can you elaborate?
moe_r - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 977
