주요 콘텐츠로 건너뛰기
Kodak EasyShare M530 Battery Replacement
필요한 것
  1. Kodak EasyShare M530 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the camera upside down so the battery compartment is towards you. Follow the arrows with your thumb to slide open the hatch to expose the battery and memory card.
  2. Kodak EasyShare M530 Battery Replacement: 2 단계, 이미지 1/1
    • This is what it should look like once it is opened. Here you can take the old battery out or take the memory card out as well.
  3. Kodak EasyShare M530 Battery Replacement: 3 단계, 이미지 1/1
    • The diagram shows the (-) side should be on your right, while the (+) side should be on your left. Insert the new battery and memory card here.
  4. Kodak EasyShare M530 Battery Replacement: 4 단계, 이미지 1/1
    • Close up the hatch and you're back to taking beautiful pictures!
결론
Close it back up and you're ready to go!
다른 한 분이 해당 안내서를 완성하였습니다.
Elizabeth
회원 가입일: 01/28/15
279 평판
안내서 2개 작성하였습니다
Penn State, Team 1-2, Kaschak Winter 2015 Penn State, Team 1-2, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S1G2
1 회원
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 36
전체 시간: 1,739
