주요 콘텐츠로 건너뛰기
Kodak EasyShare M532 Screen Replacement
필요한 것
  1. Kodak EasyShare M532 Screen  Replacement, Screen: 1 단계, 이미지 1/2 Kodak EasyShare M532 Screen  Replacement, Screen: 1 단계, 이미지 2/2
    • Open the battery compartment on the bottom of the camera and remove the battery.
  2. Kodak EasyShare M532 Screen  Replacement: 2 단계, 이미지 1/3 Kodak EasyShare M532 Screen  Replacement: 2 단계, 이미지 2/3 Kodak EasyShare M532 Screen  Replacement: 2 단계, 이미지 3/3
    • Remove two Phillips screws from each side of the camera (four screws total).
    • Remove one additional Phillips screw from the bottom of the camera.
  3. Kodak EasyShare M532 Screen  Replacement: 3 단계, 이미지 1/3 Kodak EasyShare M532 Screen  Replacement: 3 단계, 이미지 2/3 Kodak EasyShare M532 Screen  Replacement: 3 단계, 이미지 3/3
    • Inserting the prying tool as shown, gently separate the front and back pieces of the camera exterior.
  4. Kodak EasyShare M532 Screen  Replacement: 4 단계, 이미지 1/3 Kodak EasyShare M532 Screen  Replacement: 4 단계, 이미지 2/3 Kodak EasyShare M532 Screen  Replacement: 4 단계, 이미지 3/3
    • Carefully remove the front and back exterior pieces from the camera body.
  5. Kodak EasyShare M532 Screen  Replacement: 5 단계, 이미지 1/3 Kodak EasyShare M532 Screen  Replacement: 5 단계, 이미지 2/3 Kodak EasyShare M532 Screen  Replacement: 5 단계, 이미지 3/3
    • Gently remove the frame with the top buttons.
    • You should now have the screen and inside parts exposed as shown.
  6. Kodak EasyShare M532 Screen  Replacement: 6 단계, 이미지 1/2 Kodak EasyShare M532 Screen  Replacement: 6 단계, 이미지 2/2
    • Lift the screen off the body. Note that it is still connected on one side by the orange tape.
    • Flip it over gently and let it rest off to the side where the tape is.
    • It is okay if the orange tape clips out of its spot.
  7. Kodak EasyShare M532 Screen  Replacement: 7 단계, 이미지 1/2 Kodak EasyShare M532 Screen  Replacement: 7 단계, 이미지 2/2
    • Remove the two Phillips screws. There is one at the top center and one in the bottom left corner.
  8. Kodak EasyShare M532 Screen  Replacement: 8 단계, 이미지 1/3 Kodak EasyShare M532 Screen  Replacement: 8 단계, 이미지 2/3 Kodak EasyShare M532 Screen  Replacement: 8 단계, 이미지 3/3
    • Remove the top Phillips screw from the right side.
    • Move the silver tape aside to access and remove the Phillips screw in the bottom corner.
  9. Kodak EasyShare M532 Screen  Replacement: 9 단계, 이미지 1/3 Kodak EasyShare M532 Screen  Replacement: 9 단계, 이미지 2/3 Kodak EasyShare M532 Screen  Replacement: 9 단계, 이미지 3/3
    • Gently pry up the clip on the top corner to release the metal casing and lift the casing out of the way.
    • The casing is also connected via an orange tape on the right side that you may leave in place.
    • Be sure to wear safety glasses while prying the clip.
  10. Kodak EasyShare M532 Screen  Replacement: 10 단계, 이미지 1/3 Kodak EasyShare M532 Screen  Replacement: 10 단계, 이미지 2/3 Kodak EasyShare M532 Screen  Replacement: 10 단계, 이미지 3/3
    • Find the silver clip where the orange tape from the screen attaches to the circuit board.
    • Lift up the silver clip. The orange tape will slide out, completely disconnecting the screen from the camera.
결론
Samantha Vasquez
회원 가입일: 05/31/16
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 23
전체 시간: 815
