1. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
    • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Next, press down on the red lever which holds the battery in place.
    • Next, press down on the red lever which holds the battery in place.
  4. Once the battery has popped out of the compartment, simply pull it out of the camera. Once the battery has popped out of the compartment, simply pull it out of the camera.
    • Once the battery has popped out of the compartment, simply pull it out of the camera.
결론
Jack
회원 가입일: 2010년 10월 10일
172 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010 회원
CPSU-MANESS-F10S5G16
4 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 1,681
