주요 콘텐츠로 건너뛰기
Kodak EasyShare Z1015 IS SD Memory Card Replacement
필요한 것
  1. Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: 1 단계, 이미지 1/2 Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: 1 단계, 이미지 2/2
    • In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left.
    • Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
  2. Kodak EasyShare Z1015 IS SD Memory Card Replacement: 2 단계, 이미지 1/2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: 2 단계, 이미지 2/2
    • After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step.
  3. Kodak EasyShare Z1015 IS SD Memory Card Replacement: 3 단계, 이미지 1/2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: 3 단계, 이미지 2/2
    • After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
katie newman
회원 가입일: 10/28/10
30 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010 회원
CPSU-MANESS-F10S5G16
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 2,749
