소개
The back cover of the camera must be removed to gain access to the LCD screen and other important interior parts of the camera. If one of these pieces needs to be accessed or the back cover gets scratched or damaged you may need to replace this piece. Follow this guide to complete the replacement.
필요한 것
Slide the door on the bottom of the camera in the direction of the open symbol with your finger.
Release and the door will pop open.
Flip open the door on the right side of the camera, when looking at the LCD screen.
Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
Remove a total of six 3.968mm Phillips #00 screws. Two each from the left side, bottom, and right side.
다른 한 분이 해당 안내서를 완성하였습니다.
