주요 콘텐츠로 건너뛰기
Kodak EasyShare Z740 Back Cover Replacement
필요한 것
  1. Kodak EasyShare Z740 Back Cover Replacement, Battery: 1 단계, 이미지 3개 중 1개 Kodak EasyShare Z740 Back Cover Replacement, Battery: 1 단계, 이미지 3개 중 2개 Kodak EasyShare Z740 Back Cover Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the door on the bottom of the camera in the direction of the open symbol with your finger.
    • Release and the door will pop open.
  2. Kodak EasyShare Z740 Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery out.
  3. Kodak EasyShare Z740 Back Cover Replacement, SD/MMC: 3 단계, 이미지 3개 중 1개 Kodak EasyShare Z740 Back Cover Replacement, SD/MMC: 3 단계, 이미지 3개 중 2개 Kodak EasyShare Z740 Back Cover Replacement, SD/MMC: 3 단계, 이미지 3개 중 3개
    • Flip open the door on the right side of the camera, when looking at the LCD screen.
    • This door has a memory card and A/V OUT symbol on it.
  4. Kodak EasyShare Z740 Back Cover Replacement: 4 단계, 이미지 2개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Gently push SD/MMC to eject.
  5. Kodak EasyShare Z740 Back Cover Replacement: 5 단계, 이미지 2개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Pull SD/MMC out of the camera.
  6. Kodak EasyShare Z740 Back Cover Replacement, Lens Cover: 6 단계, 이미지 2개 중 1개 Kodak EasyShare Z740 Back Cover Replacement, Lens Cover: 6 단계, 이미지 2개 중 2개
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
  7. Kodak EasyShare Z740 Back Cover Replacement: 7 단계, 이미지 3개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 7 단계, 이미지 3개 중 2개 Kodak EasyShare Z740 Back Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
  8. Kodak EasyShare Z740 Back Cover Replacement: 8 단계, 이미지 2개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 8 단계, 이미지 2개 중 2개
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
  9. Kodak EasyShare Z740 Back Cover Replacement: 9 단계, 이미지 3개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 9 단계, 이미지 3개 중 2개 Kodak EasyShare Z740 Back Cover Replacement: 9 단계, 이미지 3개 중 3개
    • Separate the two pieces of the loop and pull the lens cover up in between them.
  10. Kodak EasyShare Z740 Back Cover Replacement: 10 단계, 이미지 3개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 10 단계, 이미지 3개 중 2개 Kodak EasyShare Z740 Back Cover Replacement: 10 단계, 이미지 3개 중 3개
    • Pull the lens cover and the sting will come out of the metal slab.
  11. Kodak EasyShare Z740 Back Cover Replacement, Back Cover: 11 단계, 이미지 3개 중 1개 Kodak EasyShare Z740 Back Cover Replacement, Back Cover: 11 단계, 이미지 3개 중 2개 Kodak EasyShare Z740 Back Cover Replacement, Back Cover: 11 단계, 이미지 3개 중 3개
    • Place lens cover back on the lens to prevent scratches or debris but leave string detached.
    • Remove a total of six 3.968mm Phillips #00 screws. Two each from the left side, bottom, and right side.
  12. Kodak EasyShare Z740 Back Cover Replacement: 12 단계, 이미지 3개 중 1개 Kodak EasyShare Z740 Back Cover Replacement: 12 단계, 이미지 3개 중 2개 Kodak EasyShare Z740 Back Cover Replacement: 12 단계, 이미지 3개 중 3개
    • Pull the back cover away from the front cover.
    • You may need to use a plastic opening tool as a wedge if it does not come apart by easily.
  13. Kodak EasyShare Z740 Back Cover Replacement: 13 단계, 이미지 1개 중 1개
    • Separate the back cover from the front cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kirsten Price
회원 가입일: 09/17/14
442 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 1,156
