주요 콘텐츠로 건너뛰기
Kodak EasyShare Z740 Lens Cover Replacement
  1. Kodak EasyShare Z740 Lens Cover Replacement, Lens Cover: 1 단계, 이미지 1/2 Kodak EasyShare Z740 Lens Cover Replacement, Lens Cover: 1 단계, 이미지 2/2
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
  2. Kodak EasyShare Z740 Lens Cover Replacement: 2 단계, 이미지 1/3 Kodak EasyShare Z740 Lens Cover Replacement: 2 단계, 이미지 2/3 Kodak EasyShare Z740 Lens Cover Replacement: 2 단계, 이미지 3/3
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
  3. Kodak EasyShare Z740 Lens Cover Replacement: 3 단계, 이미지 1/2 Kodak EasyShare Z740 Lens Cover Replacement: 3 단계, 이미지 2/2
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
  4. Kodak EasyShare Z740 Lens Cover Replacement: 4 단계, 이미지 1/3 Kodak EasyShare Z740 Lens Cover Replacement: 4 단계, 이미지 2/3 Kodak EasyShare Z740 Lens Cover Replacement: 4 단계, 이미지 3/3
    • Separate the two pieces of the loop and pull the lens cover up in between them.
  5. Kodak EasyShare Z740 Lens Cover Replacement: 5 단계, 이미지 1/3 Kodak EasyShare Z740 Lens Cover Replacement: 5 단계, 이미지 2/3 Kodak EasyShare Z740 Lens Cover Replacement: 5 단계, 이미지 3/3
    • Pull the lens cover and the sting will come out of the metal slab.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kirsten Price
회원 가입일: 09/17/14
406 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 15
전체 시간: 665
