주요 콘텐츠로 건너뛰기
Kodak Easyshare V1003 Lens Replacement
필요한 것
  1. Kodak Easyshare V1003 Lens  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003 Lens  Replacement: 2 단계, 이미지 1개 중 1개
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003 Lens  Replacement: 3 단계, 이미지 1개 중 1개
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003 Lens  Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003 Lens  Replacement: 5 단계, 이미지 2개 중 1개 Kodak Easyshare V1003 Lens  Replacement: 5 단계, 이미지 2개 중 2개
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003 Lens  Replacement, Lens: 6 단계, 이미지 2개 중 1개 Kodak Easyshare V1003 Lens  Replacement, Lens: 6 단계, 이미지 2개 중 2개
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003 Lens  Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the outer case off using the plastic opening tool.
  8. Kodak Easyshare V1003 Lens  Replacement: 8 단계, 이미지 2개 중 1개 Kodak Easyshare V1003 Lens  Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the LCD display by unplugging the connector
    • Take apart the LCD display from the back case
  9. Kodak Easyshare V1003 Lens  Replacement: 9 단계, 이미지 2개 중 1개 Kodak Easyshare V1003 Lens  Replacement: 9 단계, 이미지 2개 중 2개
    • Peel off the yellow film.
    • Peel off the black tape holding the wires.
  10. Kodak Easyshare V1003 Lens  Replacement: 10 단계, 이미지 1개 중 1개
    • Unplug the connector by lifting the little lock holding it in place.
  11. Kodak Easyshare V1003 Lens  Replacement: 11 단계, 이미지 2개 중 1개 Kodak Easyshare V1003 Lens  Replacement: 11 단계, 이미지 2개 중 2개
    • Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
  12. Kodak Easyshare V1003 Lens  Replacement: 12 단계, 이미지 3개 중 1개 Kodak Easyshare V1003 Lens  Replacement: 12 단계, 이미지 3개 중 2개 Kodak Easyshare V1003 Lens  Replacement: 12 단계, 이미지 3개 중 3개
    • Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
    • Gently pull out the lens using you finger tips or pincers.
결론
작성자
4다른 기여자 명과 함께
Sarah Berry
회원 가입일: 03/21/17
313 평판
안내서 3개를 작성함
UMass Dartmouth, Team S9-G4, Martin Spring 2017 UMass Dartmouth, Team S9-G4, Martin Spring 2017 회원
UMASSD-MARTIN-S17S9G4
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 6
전체 시간: 397
