주요 콘텐츠로 건너뛰기
Kodak Easyshare Z981 Bottom Panel Replacement
필요한 것
  1. Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: 1 단계, 이미지 1/2 Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 Bottom Panel Replacement: 2 단계, 이미지 1/3 Kodak Easyshare Z981 Bottom Panel Replacement: 2 단계, 이미지 2/3 Kodak Easyshare Z981 Bottom Panel Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Phillips #00 Screwdriver
    $5.49
    구매
    • Use a 00 Phillips-Head screwdriver
    • Remove the 3 mm screws from the camera.
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  3. Kodak Easyshare Z981 Bottom Panel Replacement: 3 단계, 이미지 1/1
    • Start from a corner and gently remove the bottom cover.
    • The cover will easily lift off, so not much pressure is required.
    • Be gentle while removing the cover, to avoid breaking the plastic
  4. Kodak Easyshare Z981 Bottom Panel Replacement: 4 단계, 이미지 1/3 Kodak Easyshare Z981 Bottom Panel Replacement: 4 단계, 이미지 2/3 Kodak Easyshare Z981 Bottom Panel Replacement: 4 단계, 이미지 3/3
    • Remove the bottom of the battery cover first, and then the top.
    • The hinge is simple, the screwdriver is no longer necessary.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Olivia Boyna
회원 가입일: 03/03/15
509 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 13-6, Blackburne Winter 2015 Sam Houston State, Team 13-6, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G6
3 회원들
안내서 10개 작성하였습니다
댓글 6개
where can i buy it?
Lizette Nin - 답글
PLEASE help? I can't find this part anywhere?
thecarlisles - 답글
Did anyone ever find the parts to complete this task? It's exactly what I need to do but cant find the bottom plate anywhere.
Billy T - 답글
I need the bottom panel also. If anyone knows where to purchase it please email me kpw1god@yahoo.com
kpw1god - 답글
I HAVE THE SAME QUESTION. WHERE  ARE THE PARTS BOUGHT??????? WHY PUT THIS OUT  IF U CAN’T BUY THE PARTS?? bILL     RENTMRBILL@YAHOO.COM
rentmrbill - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 17
전체 시간: 2,224
