주요 콘텐츠로 건너뛰기
Kodak S100 EF Back Cover Replacement
필요한 것
  1. Kodak S100 EF Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 Kodak S100 EF Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Back Cover Replacement: 2 단계, 이미지 1/1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Back Cover Replacement: 3 단계, 이미지 1/1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
결론
Michelle
회원 가입일: 04/04/11
107 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 회원
CPSU-GARNER-S11S25G28
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,540
