주요 콘텐츠로 건너뛰기
Kodak S100 EF Front Cover Replacement
필요한 것
  1. Kodak S100 EF Front Cover Replacement, Front Cover: 1 단계, 이미지 1/1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Front Cover Replacement: 2 단계, 이미지 1/1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Front Cover Replacement: 3 단계, 이미지 1/1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
결론
Michelle
회원 가입일: 04/04/11
107 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 회원
CPSU-GARNER-S11S25G28
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,992
