주요 콘텐츠로 건너뛰기
Kodak S100 EF Lens Replacement
필요한 것
  1. Kodak S100 EF Lens Replacement, Front Cover: 1 단계, 이미지 1/1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Lens Replacement: 2 단계, 이미지 1/1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Lens Replacement: 3 단계, 이미지 1/1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  4. Kodak S100 EF Lens Replacement, Lens: 4 단계, 이미지 1/1
    • Remove the two 6.2mm Phillips screws on either side of the lens securing the metal plate.
  5. Kodak S100 EF Lens Replacement: 5 단계, 이미지 1/1
    • Pull aside the plastic piece resting atop the metal lens plate in order to access the other screws.
  6. Kodak S100 EF Lens Replacement: 6 단계, 이미지 1/1
    • To remove other screws, metal panel must be lifted up slightly to access.
    • Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
  7. Kodak S100 EF Lens Replacement: 7 단계, 이미지 1/1
    • Look at the black plate on the right side of the lens that the metal plate is resting on.
    • Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
    • At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
결론
Michelle
회원 가입일: 04/04/11
107 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 회원
CPSU-GARNER-S11S25G28
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,877
