이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unscrew the 6.2mm Phillips screw on the top right.
The front cover is now unscrewed and should be lifted evenly and removed.
Remove the two 6.2mm Phillips screws on either side of the lens securing the metal plate.
Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
