주요 콘텐츠로 건너뛰기
Kolcraft Cloud Plus "Free-Stand" Button Replacement
필요한 것
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: 1 단계, 이미지 1/2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: 1 단계, 이미지 2/2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: 2 단계, 이미지 1/1
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: 3 단계, 이미지 1/1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: 4 단계, 이미지 1/1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
결론
Christopher Peterson
회원 가입일: 10/01/15
330 평판
안내서 3개 작성하였습니다
Cal Poly, Team 11-1, Forte Fall 2015 Cal Poly, Team 11-1, Forte Fall 2015 회원
CPSU-FORTE-F15S11G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 31
전체 시간: 1,271
