주요 콘텐츠로 건너뛰기
Konica Minolta DiMAGE Z3 LCD Screen Replacement
필요한 것
  1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: 1 단계, 이미지 2개 중 1개 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: 1 단계, 이미지 2개 중 2개
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: 2 단계, 이미지 1개 중 1개
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
  3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: 3 단계, 이미지 2개 중 1개 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: 3 단계, 이미지 2개 중 2개
    • Use a screwdriver to remove the four viewfinder cover screws.
  4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: 4 단계, 이미지 1개 중 1개
    • Remove the 2 small screws under the viewfinder.
  5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: 5 단계, 이미지 1개 중 1개
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
  6. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: 6 단계, 이미지 1개 중 1개
    • Remove 6 screws on the bottom panel.
  7. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: 7 단계, 이미지 1개 중 1개
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
  8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove 1 screw inside the battery chamber.
  9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
  10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the 3 screws that attach the LCD screen to the circuit board.
  11. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
  12. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
결론
작성자
4다른 기여자 명과 함께
Hieu Ngo
회원 가입일: 03/22/17
431 평판
안내서 4개를 작성함
UMass Dartmouth, Team S7-G4, Julie Spring 2017 UMass Dartmouth, Team S7-G4, Julie Spring 2017 회원
UMASSD-JULIE-S17S7G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 18
전체 시간: 958
