주요 콘텐츠로 건너뛰기
Korg Toneworks AX1500G Pedal Switch Replacement
필요한 것
  1. Korg Toneworks AX1500G Pedal Switch Replacement, Pedal Switch: 1 단계, 이미지 1/1
    • Remove the black 8.0mm Phillips screws from the back of the Pedal Board.
    • Be careful when working with small electronics, as many of the components are fragile.
  2. Korg Toneworks AX1500G Pedal Switch Replacement: 2 단계, 이미지 1/3 Korg Toneworks AX1500G Pedal Switch Replacement: 2 단계, 이미지 2/3 Korg Toneworks AX1500G Pedal Switch Replacement: 2 단계, 이미지 3/3
    • Remove the back panel of the board.
  3. Korg Toneworks AX1500G Pedal Switch Replacement: 3 단계, 이미지 1/1
    • Unscrew the five golden 8.0mm Phillips screws holding down the left circuit board.
    • Be careful not to hit to metal parts on the circuit board, this could cause sparks and failure.
  4. Korg Toneworks AX1500G Pedal Switch Replacement: 4 단계, 이미지 1/3 Korg Toneworks AX1500G Pedal Switch Replacement: 4 단계, 이미지 2/3 Korg Toneworks AX1500G Pedal Switch Replacement: 4 단계, 이미지 3/3
    • Carefully unplug three wires connecting the left circuit board to the right circuit board.
    • The wires may be stuck and difficult to remove. Try to pull from the plastic part.
  5. Korg Toneworks AX1500G Pedal Switch Replacement: 5 단계, 이미지 1/3 Korg Toneworks AX1500G Pedal Switch Replacement: 5 단계, 이미지 2/3 Korg Toneworks AX1500G Pedal Switch Replacement: 5 단계, 이미지 3/3
    • The circuit board is still connected at this point.
    • Carefully pull out the circuit board and turn it over.
    • Unplug the last cable connecting it to the other large circuit board.
  6. Korg Toneworks AX1500G Pedal Switch Replacement: 6 단계, 이미지 1/1
    • Unscrew the two 8.0 mm black Phillips screws from the small circuit board.
  7. Korg Toneworks AX1500G Pedal Switch Replacement: 7 단계, 이미지 1/3 Korg Toneworks AX1500G Pedal Switch Replacement: 7 단계, 이미지 2/3 Korg Toneworks AX1500G Pedal Switch Replacement: 7 단계, 이미지 3/3
    • Gently pull out the small circuit board by the purple wire.
  8. Korg Toneworks AX1500G Pedal Switch Replacement: 8 단계, 이미지 1/3 Korg Toneworks AX1500G Pedal Switch Replacement: 8 단계, 이미지 2/3 Korg Toneworks AX1500G Pedal Switch Replacement: 8 단계, 이미지 3/3
    • Mark the wire connected to the small circuit board so for future reference.
  9. Korg Toneworks AX1500G Pedal Switch Replacement: 9 단계, 이미지 1/3 Korg Toneworks AX1500G Pedal Switch Replacement: 9 단계, 이미지 2/3 Korg Toneworks AX1500G Pedal Switch Replacement: 9 단계, 이미지 3/3
    • Soldering Irons can be very dangerous if you are inexperienced.
    • Desolder the wires connecting to the board and remove the board.
    • Solder the new foot switch circuit on
결론
다른 3명이 해당 안내서를 완성하였습니다.
Gabriel Maraboto
회원 가입일: 09/29/15
200 평판
안내서 1개 작성함
Cal Poly, Team 14-6, Green Fall 2015 Cal Poly, Team 14-6, Green Fall 2015 회원
CPSU-GREEN-F15S14G6
5 회원들
안내서 6개 작성하였습니다
댓글 3개
Thanks! My Ax1500g's pedal switch volume is failing, and not reaching the 100% volume, not even 50%. I've opened the pedalboard and removed the pedal switch, but I notice It doesn't have any true connection to the switchboard but an LED with a PhotoSensor that may be blocked by a plastic in the pedal itself, is that how it works? I was expecting a Potenciometer.
Where can I buy the pedal switch board replacement?
309001200 PHOTO TR RPM-22PB N OR P KLM-2251 AX150 1
312051900 PHOTO SENSOR SIM-22ST Q OR R KLM-2251 AX150 1
Thanks
Martin Jofre - 답글
Bro
Thers is some noise comeing when i connect the cable
I give to one shop
3 times. I took the shop he is cheater i lost my money
I need to fix it bro
I need ur help
Samuel Arun - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 34
전체 시간: 4,850
