소개
The analogue isolator pots on the Korg Volca sample are very fragile, they can break so easily.
The replacement part that you need is a 5-pin ALPS potentiometer which is impossible to find and purchase, or sold at very high prices (for a simple pot).
With this guide I will show a DIY solution to repair your filter pots on the device.
필요한 것
The VS service manual is impossible to find, but it is well known that the two filter pots are 10K ALPS potentiometers
By online search, you can find the KORG EM-1 service manual, which uses the same kind of pot for volume control
The pot is VR2, an ALPS RK09K12C 5-pin potentiometer
By searching on old ALPS datasheets, you can find the specs for the pot and the layout
Looking at both the layout and the EM-1 schematic, we can see a shared ground (pin 1) and the remaining connections which form a dual wiper
You will need a simple 10K stereo potentiometer with 6 pins
The ALPS is a 103B, which is a linear one. I used a LOG one which works anyway (it will have a different sweep compared to a linear)
You will have to bridge the two 1-1' pins together to have a shared ground
The next step is to solder 5 cables to the pins (only one is needed in the shared ground)
You'll have to follow the layout drawn in the image
Solder the 5 wires and reassemble the VS, then check if the pot is working
To reassemble the device, follow these instructions in reverse order.
