메인 콘텐츠로 스킵하기
  1. Make sure the device is unplugged before continuing.
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Remove the single black Phillips size 0 10mm length screw on the back of the machine.
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the bottom cover from the machine and slide it down the power cord.
    • Remove the bottom cover from the machine and slide it down the power cord.
  5. Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  6. Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
결론
Wyatt Hall
회원 가입일: 2014년 10월 13일
824 평판
안내서 7개 작성하였습니다
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 회원
CPSU-MANESS-F14S6G25
4 회원들
안내서 7개 작성하였습니다
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 18
지난 30일: 43
전체 시간: 1,787
