주요 콘텐츠로 건너뛰기
Krups 963 Power Switch Replacement
필요한 것
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: 1 단계, 이미지 1/1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: 2 단계, 이미지 1/1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: 3 단계, 이미지 1/1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: 4 단계, 이미지 1/1
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: 5 단계, 이미지 1/1
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
결론
Wyatt Hall
회원 가입일: 10/13/14
842 평판
안내서 7개 작성하였습니다
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 회원
CPSU-MANESS-F14S6G25
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 3,029
