주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. Make sure the device is unplugged before continuing.
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Remove the single black Phillips size 0 10mm length screw on the back of the machine.
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Remove the bottom cover from the machine and slide it down the power cord.
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. PC 노트북 배터리
    자사가 품질을 보증하는 모든 최고 PC 브랜드 배터리.
    지금 장보기
    PC 노트북 배터리
    지금 장보기
  5. Remove the three 60mm Phillips size 0 screws holding the top cover on.
    • Remove the three 60mm Phillips size 0 screws holding the top cover on.
  6. Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture),  Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
    • Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
    • Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
  7. Remove the grey plastic ring from the rim of the filter basket holder.
    • Remove the grey plastic ring from the rim of the filter basket holder.
  8. Lift and remove the top black plastic cover from the machine.
    • Lift and remove the top black plastic cover from the machine.
  9. Use a Phillip size 2 screw driver to remove the four 15mm screws holding the pump to the machine's base. Lift the water heater up and remove it from the base.
    • Use a Phillip size 2 screw driver to remove the four 15mm screws holding the pump to the machine's base.
    • Lift the water heater up and remove it from the base.
결론
Wyatt Hall
회원 가입일: 2014년 10월 13일
824 평판
안내서 7개 작성하였습니다
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 회원
CPSU-MANESS-F14S6G25
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 1,762
