소개
If you need to disassemble your Krups CafeExpress FMA110 for repair or spare parts, follow this disassembly guide. Repairs could include a burnt-out heating element, faulty wire connection, ripped tubing, burnt-out thermal fuses, broken temperature switch, etc.
Be sure the device is unplugged before you begin disassembly to avoid burning or electrocuting yourself, which can cause serious injury.
Steps 4 and 6 require pulling silicon tubing off of the device. The tubing can rip easily, so be careful. The opening tools can help with these steps.
필요한 것
Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
Remove the metal plate.
