소개
Symptom: coffee flows out very slowly, coffee/water leaks through the machine.
This can be caused by a blocked spout, clogged with coffee residue built up over time.
This guide shows how to clean the Nespresso's spout.
필요한 것
Unplug the device from the mains. (Duh!),
Remove the water container and tray.
Remove the 4 bottom screws that hold the side panels. You need the oval drive bit for this.
Leave the other 2 bottom screws in place, these hold the bottom plate in place.
Put the machine on one side, gently push the bottom edge of the side panel towards the top and lift it out.
Unhook the panel from the top.
Repeat with the other side panel.
Use a Torx T120 to remove the two black screws that hold the lever, one on each side.
Open the lever and slide it upwards from its axle.
Use a Torx T10 to remove the 2 screws that hold the cover of the brew unit at the front
Remove the last screw (T10) of the cover, located at the back and underside.
Slide the brew unit cover back so that it comes free.
No force needed, some manipulation will do the trick.
Locate the clips that hold the brew unit, one on each side.
With your thumb(nail), push one sideways and and forward so that it frees the clip.
Repeat on the other side.
With both clips unlocked, remove the spout with a tilting downward motion.
Use a Torx T10 ro remove the 4 screws that hold the the brew unit, 2 on each side.
Lift the back of the brew unit.
Pull it backward until free.
Put it next to the machine, but do not put much strain on the hose.
Clean the spout, the front of the brew unit and anything that needs cleaning.
Once dry, it is ready to reassemble.
